Lets talk ECMs :D
ok, I'm looking for an exact reason as to why I can't use a ECM from a Silverado with a 5.3 to bolt up to a manual, because the transmission is controlled by a TCM isn't it? or is it made in to one complete unit?
How would a Stock ECM for a 5.3 react to Shorter intake? such as a ls1 or ls2? surely there would be some tuning involved in this I would think.
Will using a lower fuel pressure on this ECM make it freak out and cause a No-Start condition? or to high for that matter?
as far as integration, I'm not sure how the Gauges and everything will work on my Cluster, is that even possible for a Camaro?
will this ECM have to be flashed because of VIN recognition? I'm pretty sure it wouldn't have that on it, but I want to make sure I have my bases Covered in one post.
thanks.
thanks.
you could flash it for proper calibration, manual trans etc by putting a car program in it. The ecm's of the same series are identical be it manual trans auto etc, the difference in the software
If the controller is the same then it won't matter. As above its the calibration that matters as it needs to be compatible with the car. VIN numbers don't matter to the car itself in most instances. HPTuners does rely on VIN numbers for licensing for some stupid reason so that me be where your confused about controller compatibility. If that is all that is holding you back then get the VIN changed and an appropriate cal flashed in with another tuning suite like EFI LIVE that offers more freedoms in this regard.
The only way you're going to use the Silverado PCM is to reflash is with the F-body OS.
As long as you have an F-body OS in the PCM, F-body shouldn't have an issue with the VIN, F-bodies use a PWM modulated VATS signal, so it doesn't check the the VIN, the Silverado OS on the other hand uses a serial VATS system and does compare the VIN.
thank you for the replies!
So it looks like no matter what I do I have to have it flashed. so is this something that can be done Easier (and by easy I mean cheaper) by me or having someone else do that for me? I don't plan on doing much in the way of Future mods to it. Exhaust, maybe, MAYBE cam later on down the line.
I am a new member but have referred to the forums for many years now. I searched for what I am going to ask but nothing close to my scenario I believe. Here goes: a 98 t/a body with all 2001 t/a ls1,t-56 body wiring harness, 2000 t/a engine harness, 2004 gto ls1 completly refitted for trans am. Now knowing what I have what kind of ECM and or flashing would I need. Asked a seller of eBay an he said it would cost $250 and cost of shipping. Any clues and or comments are greatly appreciated, Thanks!
