Smog fail. need to run leaner
Old Sep 13, 2010 | 02:11 PM
qs_zo6's Avatar
Default Smog fail. need to run leaner
My 02 z06 barely failed the smog test. Seems im running a bit rich. what the best way to lean out using hp tuners?
Old Sep 13, 2010 | 02:55 PM
edcmat-l1's Avatar
How bout posting the test results, and the mods done to your car. Tune file would help too.
Old Sep 13, 2010 | 05:45 PM
qs_zo6's Avatar
lg longtubes w/cats
haltech trap w/license plate cut out
borla stinger exhaust
tune and smog attached. thanks
File Type: hpt
Old Sep 13, 2010 | 09:14 PM
Frost's Avatar
how old are your front o2's?
Old Sep 13, 2010 | 09:22 PM
SoCal01z28's Avatar
IMO 0.3 CO2 isn't really excessively rich. My guess would be your cat's aren't very efficient. How long was the car off before they put it on the rollers?
Old Sep 13, 2010 | 10:13 PM
Frost's Avatar
It's his HC count
Old Sep 13, 2010 | 10:17 PM
qs_zo6's Avatar
i drove for an hour to get the cats hot and put it straight on the rollers.
frost is correct my HC is high. what can i do to bring it down?
Old Sep 14, 2010 | 06:10 AM
MUSTANGBRKR02's Avatar
How old are they?
Old Sep 14, 2010 | 12:52 PM
SoCal01z28's Avatar
It's his HC count
I understand that, but he said he's rich. CO% is a direct indicator of a/f mixture.....
Old Sep 14, 2010 | 01:03 PM
qs_zo6's Avatar
Originally Posted by MUSTANGBRKR02
How old are they?
they or the factory o2s 37000 miles
Old Sep 14, 2010 | 01:29 PM
qs_zo6's Avatar
Are there any quick tweaks to bring down the HC for the few minutes of the smog? Not hurting the engine of course then i can go back to my original tune.
Old Sep 14, 2010 | 03:59 PM
Frost's Avatar
...but they are 9 years old...
Old Sep 14, 2010 | 04:16 PM
whtrashferrari's Avatar
Default hmmm
I really hope they dont get emissions in oklahoma or were all screwed out here lol . you can use hp tuners to lean out your car but you need to make sure everything else is in order .. are your headers leaking ? o2s fluctuating or are they lazy? lots of things can cause a rich condition
Old Sep 15, 2010 | 01:56 PM
qs_zo6's Avatar
anyone have suggestions on tweaks i can do or do i need to buy new 02s and pray it passes?
Old Sep 15, 2010 | 02:27 PM
RooRnZ28's Avatar
i think you need a new set of cats. Get a new, high quality set and you should be ok. The o2's are probably fine since you aren't throwing any codes.
I went thru the same **** with ca smog... put the factory manifolds and cats back on and I passed.
Old Sep 15, 2010 | 02:33 PM
edcmat-l1's Avatar
If you have your own software, run a data log of it idling. In the data log, include fuel trims, both short and long term, and both upstream and downstream O2s. I would almost guarantee it's a catalyst efficiency issue. Both your Hcs and CO2 are borderline. If it is a catalyst efficiency problem, not much you can do with high flow cats. Shoot me a PM for more details.
Looking back at your mods, I believe the LG longtubes put the cats way in the back, as opposed to right behind the headers. They never get hot enough (the cats) to kick on.
Old Sep 15, 2010 | 03:04 PM
jimmyblue's Avatar
Moderator
I think you want brand new O2 sensors and you want them
as hot as possible. The headers hurt that, making the sensors
switch more slowly and when they do your mixture (while on
average, perhaps right) spends a lot more time off in the
weeds, lean, rich, lean rather than tight, tight, tight. Out in
the weeds is where you make HC. If you want to look into
this, turn off the filtering on your wideband and log real time
idle AFR. If it's bouncing crazy, there's your HC.
I'd consider wrapping the collector for maybe 6" before and
after the sensor with a heat barrier. At least until you get
your sticker.
Old Sep 15, 2010 | 07:39 PM
joecar's Avatar
+1 on taking logs to see how O2's are switching... you probably do need new 02 sensors.
Are coldair/headers/exhaust the only mods you have...? Your emissions should be well below the average. I can't read the .hpt file, so summarize for us what has been edited in the tune.
How did you get past visual...?
