PCM Remap/Tune
Old Oct 6, 2010 | 07:19 AM
LS1Upgrade's Avatar
Default PCM Remap/Tune
I have an LS1 engine about to be dropped into a silverado 1500, just finished up the wire harness. I need someone to tune my truck PCM. I am using the following truck equipment: harness, PCM, throttle body, O2, and single wire oil pressure sending unit. At this point thats all i think i need. I would like to use the following equipment from the LS1: Maf and air temp sensor. Everything else should be the same. I also what a pin call out for an electric fan. I need a source to remap my truck PCM, any suggestions? Also how much should i expect to pay?
Old Oct 6, 2010 | 09:39 PM
LS1Upgrade's Avatar
Default Whats the difference between Tuning and Remaping
I need some help, I have a non LS1 PCM and need to have it re-programed to work with the LS1 engine can any one help me? I need a suggestion who should i use?
Old Oct 6, 2010 | 10:35 PM
Frost's Avatar
It can be done through here: http://www.tunedbyfrost.com/products_m04.htm
If you decide to bring the truck to the shop for full tuning, you get $100 of that mail roder cost credited against full tuning.
Old Oct 7, 2010 | 06:00 AM
LS1Upgrade's Avatar
Frost thank you for getting back to me. I can send the PCM out to you for an initial mail order tune, but then bring it in for a dyno tune. Based on what i was reading on your site, average cost for dyno is a hundred bucks, i am assuming i could use my credit?
Again thank you for getting back to me
