Stock Short Pulse Adder table values?
Old Oct 16, 2010 | 06:42 PM
crainholio's Avatar
Default Stock Short Pulse Adder table values?
Can anybody post the stock Short Pulse Adder table values for 2001 F-body or equivalent?
I use LS1Edit, don't have that table, and need to get them documented for comparison against what I'm calculating I need for Ford 30# injectors to compensate for their low-slope breakpoint.
Any help greatly appreciated.
Old Oct 17, 2010 | 12:17 PM
crainholio's Avatar
Nevermind, got it.
These new Ford 30# "skinny" injectors are significantly different from the stock 28# Delphi injectors, and not just the flow rate.
Just updating the IFR table to values calculated with RedHardSupra's spiffy Excel sheet got me a crappy idle and max positive LTFTs. I plugged in 39.15psid and 30# as the specs, with 58psid as the new pressure, but it idled poorly and ran ragged at cruising speeds.
Using the Ford published calibration, I found the offsets are nearly 50% higher (Ford injectors open slower than Delphi), and the Short Pulse Adder is nearly 30% lower (less low-slope correction needed below the breakpoint.)
It would have been quicker (and therefore cheaper) to just buy Greg Banish's DVD and get his specs for these new injectors...
