4l80e swap no segment available
Old Oct 30, 2010 | 02:55 PM
CalEditor's Avatar
Originally Posted by joecar
OS 12212156 came with either segment (depending on vehicle) and either of electronic/cable throttle.
These will run in a 0411 (512kb) PCM
The Van Calibration would have to be reworked to work with 4LO, but it will run a 350
The Escalade is for a LQ9, but it will need to be reworked for 4LO
  • C5W - GVW RATING 7,000 LBS
  • EVA - TEST DVT, EVAP EMISSION REQ
  • FE9 - FEDERAL EMISSIONS
  • GT4 - AXLE REAR 3.73 RATIO
  • G80 - AXLE POSITRACTION LIMITED SLIP
  • JL4 - CONTROL ACTIVE BRAKE
  • K47 - AIR CLEANER HIGH CAPACITY
  • KUP - THROTTLE CONTROL ELECTRONIC "DBW"
  • LQ9 - 8 CYL, 6.0L, HIGH OUTPUT ENGINE
  • M32 - 4-SPD AUTOMATIC TRANSMISSION
  • NF2 - EMISSION SYSTEM FEDERAL, TIER 1
  • NP3 - TRANSFER CASE ALL WHEEL DRIVE
  • Z55 - CHASSIS PACKAGE BI-STATE REAL TIME DAMPING
  • Z82 - TRAILER PROVISIONS SPECIAL EQUIP H.D.
The K2500HD is a LQ4 with an EGR valve and Cable Drive
  • C6W - GVW RATING - 9,200 LBS
  • FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS
  • *** No EVAP Emissions Test Diagnostics ***
  • GT5 - REAR AXLE - 4.10 RATIO
  • G80 - LOCKING DIFFERENTIAL-REAR AXLE
  • HVY - IDEN 2 INCH BODY RAISE,HD MODEL
  • K47 - HIGH CAPACITY AIR CLEANER
  • LQ4 - VORTEC 6000 V8 SFI GAS ENGINE
  • MT1 - HD 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE
  • NA4 - HEAVY DUTY EMISSIONS *** No Catalyst Monotoring ***
  • NF2 - FEDERAL EMISSION SYSTEM
  • NP1 - ELECTRONIC SHIFT TRANSFER CASE
  • Z85 - HEAVY DUTY SUSPENSION
If you need a 2wd 6.0L 4L80E calibration I have one also
Old Oct 30, 2010 | 05:58 PM
CalEditor's Avatar
I have a flex fuel calibration if you want that also
Old Oct 30, 2010 | 06:57 PM
CalEditor's Avatar
Originally Posted by blazerboy72
Is there anyway I can control a 4l80e with a pcm that a 4l80e segment isn't available for? My pcm is a 99 with OS 9379910.
Your original question
Yes this OSID supports the 4L80E from the factory. I just pulled up a 1999 k2500HD with a 6.0L, 4l80E, and RPO VYU, SNOW PLOW provisions
I don't have my MDI or Tech II at home with me, so I can't give you that file today, but yes the 9379910 had the option for a 4L80E
Old Sep 7, 2011 | 06:37 AM
6ltr's Avatar
Any 2wd LQ4 4L80E DBW file?
I just swapped to 4L80E and need the file to try and rework it with my current tune...
Old Sep 8, 2011 | 09:36 AM
CalEditor@PCMCalibrators's Avatar
What year?
I just pulled a 2005 C1500 6.0L with an 80 out. I could go read it if you would like it.
I have most years
Old Sep 8, 2011 | 10:52 AM
6ltr's Avatar
mine is an 06 PCM with 2003 Lq4 and 80e
Old Sep 8, 2011 | 11:05 AM
6ltr's Avatar
oh forgot to mention its a truck
Old Jun 26, 2014 | 12:18 PM
TexasGMC08's Avatar
can you post file???
