Please Expalin SPEED DENSITY TUNING
SD = PCM calculates the cylinder fill airmass using VE, MAP, IAT, and RPM.
VE is the table telling the PCM how much mass/volume the cylinder fill is at any RPM vs MAP.
When running with MAF, the PCM uses both MAF and VE at various times.
When running SD, the PCM obviously ignores MAF.
With your non-stock intake manifold, either way (MAF or SD) requires correcting both MAF and VE tables (the intake manifold change will alter airflow thru the MAF sensor, the MAF sensor was previously calibrated for it's immediate surroundings).
Either way you have to pay for a tune; SD eliminates the [cost of] the MAF sensor.
Eliminating the MAF sensor protects the PCM's airmass calculation from incorrect intake plumbing (bends too close to MAF) and from reversion effects.
Running SD is a fail-over mode and so it has side-effects, for example: spark timing adapt now defaults to low octane spark table (you lose the sliding between the HO and LO tables), and transmission pressure adapt defaults to fault mode (max pressure, no shift feel adapts), and other things not fully known.
SD = PCM calculates the cylinder fill airmass using MAP, IAT, VE and RPM.
also has ANYONE RAN THE TSP 100mm MAF? I am interested in it but has that had tuning issues? i havent seen much of anything about it
lol nope i dont deal with redline, if i could direct you to some 1 whos 20mins from redline in clifton park, Anthony Coppola, www.coppolamotorsports.com very good knowladgeable guy
one thing I'd like to add is that with a MAF tune it still takes data from the map sensor and enters it into the calculation.
My advice do your research find a tuner your comfortable with and work with him to come up with what is best for your car.
All the things above mentioned spark tables, lines pressures etc can all be changed so i dont see the issue running mafless.
I assume the reason all you guys stay with the MAF is for emission reasons, but having said that the main reason its removed over here is because the standard MAF is a restriction if you had a 100mm MAF then it would make no difference also its not going to make any power difference unless your removing the stock MAF or a restrictive MAF, your also said to gain better throttle response.
So either get a big maf that flows alot of cfm's or just take it over and run mafless.
