06 gto engine harness with ls1 computer?
Here is what i have ..... 1968 ss camaro with an ls2 swap in progress... I just picked up a 2006 gto harness of an ls2... my ls2 came out an 2006 trailblazer ss with a 58 reluctor wheel. I would like to run a cable driven throttle body... First, what computer should i buy? keep in mind, i can change the reluctor wheel bc im storking it and procharging it. Tell, me which way i should go.. im kinda lost lol
If you swap in the 24X you can run a PCM with the IAC drivers. All 1999 to 2002 will work. These are the 2003+
PCM's with IAC drivers Green is good Red is not
SERV. NO.- HWD NO. -
12576106 - 12570558 - 2003 G-VAN, LM7, IAC DRIVERS INSTALLED. ALSO C-TRUCK LM7
12582605 - 12580786 - 2003 C-MPV, L59
12586242 - 12583660 - 2004 C/K-TRUCK, LM7
12586243 - 12583659 - 2004 GTO LS1, IAC DRIVERS INSTALLED
12589463 - 12589162 - 2005 C/K-TRUCK/MPV, LM7, LQ4
12589462 - 12589161 - 2005 G-VAN, LQ4, IAC DRIVERS INSTALLED
12589463 - 12589162 - 2006 C-PICKUP, LM7
12602802 - 12589162 - 2006 C-PICKUP, L59
12602801 - 12589161 - 2006 - 2007 Express, Drive by Wire, (has IAC drivers)
