Trans tune problems!
I'm just completley lost as to what the problem is at to if it's the tune and something wasnt programmed right for the new set up because I know the P0751 code wasnt deleted because it threw it multiple times after leaving Vengeance or if it is the actual converter itself but it was supposed to have been checked along with the rest of transmission before I got it back yesterday.
I'm supposed to have the car back at Vengeance on Monday but honestly I wanted to know if there was anything else I could try/do to get my over drive working again because I don't have access to a trailer and it's about a 1 1/2 hour drive from where I am to Vengeance down the interstate and I'm afraid if I drive the car there with the shape it's in I could damage something even further. I also wanted some feed back on my problem as to what you guys think it is/might be.
Thanks!
Though I do think the trans has mechanical problems based on what he's described, the symptoms quoted below are not that unusual with a stall converter even as small as 2400 because some brands have more slippage than others. Of course you should always use the brake to hold the car on an incline.
