Mysterious Problem!
Here's what I've tried: Replaced the TPS with no luck. Tried different throttle bodies with no luck, and I just replaced the TPS wiring harness/plug with no luck. I soldered the new TPS harness/plug in last night and let it reset before start up. When I started the car, it idled real high and funny for a few seconds and then settled down. I drove it down the road and it drove perfect! During my drive, I shut the car off at a stop light and restarted it and it instantly started idling and driving bad again...with the same problems as before. It's like if I let the TPS reset it'll drive fine, with the exception of a weird start up idle. I have no more ideas!
A friend of mine told me I may need to replace to Operating System. Anyone have any input on that? I'm at a loss right now. Any help would be extrememly appreciated! And sorry for the looonnngggg post!
About a CEL. Every once in a while I'll get a code for the TPS. I can't remember the actual code number though. It's weird, cause the light will be on a while and then out of nowhere, it will go off. Hope this all made sense.
I'm going to try running new wiring for the TPS all the way to the PCM and seeing what that does. Just another update on my piece! Thanks!
Bill, just let me know when you're free...I'll work around your schedule.
Bill, thanks so much. Just let me know whenever you're free...I'll work around your schedule.
Oops, stupid internet connection!
