LS1 LS3 and Truck Injector Connections
Old 11-15-2010, 11:57 PM
TrippyJoey's Avatar
Default LS1 LS3 and Truck Injector Connections
These 3 are the choices of injectors I have for my swap, I've already searched around and it seems that with a little work I can make either of these 3 work on an LS1 manifold. My question is regarding the truck wiring harness connections for the injectors. Are the connections compatible with the LS1 and/or the LS3 and if not what company sells the adapter harness (I've read about them in some threads) to adapt either one of these injectors on a truck harness.
Yes, I know they are rated for different flows and that I will need to get the ecm retuned already.
