HWere do i find an E40 computer? not too pricey...
I need an E40 computer which comes one 05-06 GTOs and SSR's and Trailblazer SS.... Im running a 2007 TBSS engine which has 58 X wheel and im running a 2006 gto set up such as acessories and throttle bodyand pedal drive by wire... which has 24x reluctor wheel... but i still dont have a computer... now keep this in mind... i putting a new rotating assembly in so changing reluctor wheels are not a problem.. So can i upgrade to a newer computer with 58 X wheel and still running the gto harness. what are the benifits of running 58 vs 24.... thanks
you can't use the harness without replacing all of the pins on the ecm plugs, the pins from E40 to E38/E67 are different.
Do you ever want to run a 6 speed automatic trans? Or have intercooler pump control for a blower, That is the only reasonon I would look at E38/E67 swaps instead of the E40
Ryan
Ryan
