HPT rev limit help
Old Nov 21, 2010 | 10:08 AM
we_todd_did's Avatar
Default HPT rev limit help
My car wont rev past 7200 with hpt set at 9k its a 2000 camaro is there another setting I need to change other then fuel cut?
Old Nov 21, 2010 | 11:23 AM
DrkPhx's Avatar
A4 car? If so, you need to change WOT shift points.
Old Nov 22, 2010 | 07:13 AM
Mine has a powerglide in it its set on m6 i believe
Old Nov 22, 2010 | 09:43 AM
jimmyblue's Avatar
Moderator
Scan it and see if injector pulse width is bouncing. If not,
then rev limiter isn't the problem I think.
Make sure there isn't some craziness in the spark tables
/ delivered advance at higher than "normal" RPM.
