1999 wireing harnes to 2000 PCM?
I have a 2000 Trans am that I am doing an auto swap in. Can I use the wiring harness from a 1999 auto ls1 with my 2000 PCM? I want to make sure before I buy it.
thanks
thanks
Yes, they use the same PCM. The 2001/2002 PCM will also plug right into 1999-2000 car...only 98's were incompatible pinouts...you will need to get your PCM re-programmed to control the auto transmission.
Are you selling the pedals from your car? A friend of mine needs a set and I'll gladly buy them from you for him.
