How to wire an LC-1 for portable tuning
As far as making your LC1 more portable you can try the following:
-Solder some extensions to your power and ground wires.
-Add a flat male (spade type) connector to your LC1 switched 12V power wire. You can use it to slip into an available switched 12V supply found in the vehicles fuse box. It's also a good idea to have a fuse (10A I think) soldered inline with your 12V switched power of the LC1.
-Add a round (open hole) connector to your now extended ground wire.
Basically the idea is to add extra length where needed in order to make the LC1 more flexible when installing on different vehicles. If you put the right ends on the power and ground wires it really becomes plug and play.
Originally I did this to use the wideband for a narrowband signal too.
Now I'm connected to one of the rear O2 connectors and the stock pre-cat O2 sensor is back in place.
I also use the serial connection to my V2, other than that the only connection to the car is the ground.
There is info on the EFI Live site on how to wire it for the narrowband, just use that as a reference point and solder it up.
Brad
May I suggest some light reading?
http://forum.efilive.com/showthread....other-sections...
You need power/ground, and the 3-wire serial connection (wired as null-modem).
Be sure to plug the 2.5mm stereo terminator plug into the LC-1 SERIAL IN cable, make sure it snaps all the way in (lube it).
The V2 is able to command free air calibration to the LC-1, and is able to read the LC-1's status and of course the AFR/Lambda/EQR.
