Help!!!! IM New I Need Help With My PCM
So im putting a ls1 in to a 96 nissan 240sx and its ganna be basically stock except for headers and intake and exhaust.
My qestion is i wanna send the PCM out to delete VATS off of it but Whats other **** should i delete off of it. I herd something about skip shift and stuff like that. I just want a solid anwser or pointed in the right direction cuz i dont even know what to search for. thanks for the help in advance guys
this is what i have found so far is there anything else im missing
- Disable VATS and any other security feature
- Disable CAGS
- Tune out rear 2 O2 sensors
- PCM will never shut car off
- Disable any Emissions systems
- Stock M6 LS1 w/ open air intake and long-length headers
- Turn fans on at 180, turn off at 175
- Turn off Speed Limiter
- 4.08, 3.90, 3.69, 3.54, 3.36 Gear Ratio
- Stock T-56 Gears
- Remove EVAP System
- Turn off fuel level sensor
- Turn off fuel tank pressure sensor
- Skip Shift*
- Disable CAGS
- Stock T-56 Gears
- Skip Shift*
