Make '411 E85 capatable for Fbody?
Old Jan 6, 2011 | 06:39 PM
Alvin's Avatar
Default Make '411 E85 capatable for Fbody?
Just wondering if anyone has attempted this yet. There is a OS that came from GM ending in '125 that ran flex fuel with a 411 for 2001-2002 Suburbans. Are they wired the same?
HPtuners has a 2 bar OS ready for it.
Old Jan 6, 2011 | 08:55 PM
CalEditor's Avatar
Yes I have that calibration in a bin file.
The 2006 does not use a Flex Fuel sensor. It uses Virtual Flex Fuel Software.
Old Jan 6, 2011 | 09:21 PM
Alvin's Avatar
Who said anything about 2006? I have the calibration also.. So does anyone with TIS or access to the HPT repository.
The question still stands, has anyone tried it in a F-body yet?
Old Jan 6, 2011 | 09:56 PM
CalEditor's Avatar
http://www.monodax.com/forums/attach...n-12216125.bin
You can make that fit what ever you want it to fit as far as 2002
Old Jan 6, 2011 | 09:57 PM
CalEditor's Avatar
Sorry about the 2006 thing.
Yes I have TIS and HPT along with about 500 bin files.
Old Jan 6, 2011 | 10:02 PM
chevyls10's Avatar
Comparing the wiring diagram from a 2002 suburban w/flex fuel to a 2002 f-car there are many differences between the two harness and pinouts at the ecm. Combination of wiring in different spots and differences between some pins being uses/not used.
Old Jan 6, 2011 | 10:03 PM
Alvin's Avatar
I don't think you are understanding me. I have the bin, the file, etc. I DO NOT NEED THE FILE. AS IMPRESSIVE AS YOUR COLLECTION IS, IT DOES NOT ANSWER THE QUESTION
Has anyone tried it yet? They are completely different OS's. Whose to say you get that far with it and you can't get something like the fuel level gauge to not work correctly. You can just pull segments from mismatching OS types and expect it to work.
Old Jan 6, 2011 | 10:24 PM
CalEditor's Avatar
The use the same fuel template to make the fuel calibrations.
Old Jan 8, 2011 | 07:15 PM
shoemike's Avatar
It would be nice to see someone try and post the results.
Old Jan 9, 2011 | 11:38 AM
350SS's Avatar
Do the 01-02 suburbans that use the '125 OS use the flex fuel sensor?
Old Jan 12, 2011 | 11:28 AM
CalEditor's Avatar
this is a 125 bin file.
