100% b2 ltft
Old Jan 18, 2011 | 10:14 PM
firebird446's Avatar
Default 100% b2 ltft
i have a buddy with a 1998 z28 with 5.3 heads #206, CC 273XFI, typhoon intake and 85mm TB, pacesetter midtubes. we been tuning it just fine then one day the B2 LTFT is bottomed out -100% so im like wow looked at o2 voltage and its still moving like normal and car runs like a turd, ive tried reseting the fuel trims via hp tuners and it wont even move a bit off -100. then i tried to do it while the cars not running/key on and still nothing.
any help would be awesome, im leaning towards ecm messed up....
Last edited by firebird446; Jan 18, 2011 at 11:53 PM. Reason: clarify not running/ with key on
Old Jan 18, 2011 | 11:13 PM
salemetro's Avatar
Originally Posted by firebird446
i have a buddy with a 1998 z28 with 5.3 heads #206, CC 273XFI, typhoon intake and 85mm TB, pacesetter midtubes. we been tuning it just fine then one day the B2 LTFT is bottomed out -100% so im like wow looked at o2 voltage and its still moving like normal and car runs like a turd, ive tried reseting the fuel trims via hp tuners and it wont even move a bit off -100. then i tried to do it while the cars not running and still nothing.
Dead injector on bank 2?
Old Jan 18, 2011 | 11:47 PM
I wish it was that easy done checked all injectors. I should still be able to reset trims and be zero once again but it don't. I checked for intake leaks around gaskets, TB, intake boot, maf, exhaust leaks and nothing found.
Old Jan 19, 2011 | 09:23 AM
jimmyblue's Avatar
Moderator
That's a PCM brain-fart value, LTFTs peg at +/-25% and
throw a too-rich or too-lean code if it's a real, sustained
mixture error.
Old Jan 19, 2011 | 04:46 PM
Matt@SNLPerformance's Avatar
You can't log many PIDs on the 98 computer as you can on the 99+ computers. Try logging less than 23 and see if you get a normal reading from it.
Old Jan 19, 2011 | 08:59 PM
I did that and noticed I was at 25 PIDS and you was right I backed it down too 24 and now its logging just fine.
Thanks a million he was about to order a new ecu.
I have a 99 ws6 and it let's me log more just didn't realize that 98 were that much lower
