Tuning a GTO with Magnacharger using HP Tuners
05 A4 GTO E40 ecm
TVS2300, no other changes
The injectors have the same P/N as the LS9/ZR1
I have a couple of different tunes that Magnacharger provided for the TVS1900 and also older 122 blowers.
Questions:
1. In HP Tuners, both the low and high The MAF numbers are exactly the same as a stock tune. Is that correct?
2. The VE tables are also exactly the same as a stock A4 How is that possible?
3. I attached my IFR table, is it correct for 58 psi on a GTO with ZR1 injectors?
Questions:
