LS3 swap failed smog.
15 mph: RPM 1273, %CO2 15.0, %02 0.4, HC MAX 77 MEAS 4, CO% MAX 0.50 MEAS 0.01, NO MAX 541 MEAS 1658
25 mph: RPM 1238, %CO2 15.1, %02 0.2, HC MAX 59 MEAS 3, CO% MAX 0.41 MEAS 0.01, NO MAX 498 MEAS 1127
This is a bone stock GMPP crate LS3 in a C4. All of the sensors are brand new and it has stock C6 manifolds and cats. I am running an E67 ECM and it currently has some canned tune from Current Performance which I have not looked into yet.
I also have four codes that are showing up... P0053, P0054, P0059, P0060 which are all oxygen sensor heater resistance codes.
Here are a couple pictures I took of my generic scan tool while the car was at idle if that helps any.
Could this tune be excessively lean? I also noticed the rear o2 sensor on bank one is around .460 while the rest are around .45.
Thanks in advance for your help!!
