Will someone take a look at my log (hpt)
I agree with Frost 100%. A banging y-pipe will read as false knock, however it will not cause a P0327 code or constant knock retard. If the y-pipe was causing the knock retard it would probably only show up under moderate and heavy throttle input, where the y-pipe would bang the most. It looks like it's registering knock pretty much across the board.
