Predator
Old Feb 13, 2004 | 04:00 PM
GMCAMARO's Avatar
Default Predator
Is there any reason that LS1edit could not write over a predator tune?
I have a 99, and after an LS1edit was used over a predator tune, the drivers side bank started misfiring badly, particularly 1,3 and 5.
The coils where replaced along with wires and injectors. It helped for about 5 seconds, and then reappeared. The problem appeared to go away when the computer was flashed with the stock program and then reset using LS1edit.
Any thoughts?
Old Feb 15, 2004 | 04:07 PM
blackend02's Avatar
i had the predator tune on my vet and i have no problem tuning over it with edit
Old Feb 15, 2004 | 05:16 PM
gojo's Avatar
Any thoughts?
Put back your stock tune and then install your Edit tune. I may be wrong but I think Edit does not rewrite all the files each time. You may have a conflict. In any case that's what I would try, using the "It can't hurt" rule.
