big dip in dyno graph-have a look!
Old Feb 20, 2011 | 10:23 AM
STAR's Avatar
Default big dip in dyno graph-have a look!
I recently hit the dyno with the some changes being made to my combo and overall very happy except for a dip that occurs on the graph. I'm not sure if its related to the torque converter, dyno pick up interference or possibly in the tune.
The combo is basically a stock bottom LS2 with ported heads and a cam. The power is transfered to the rear through a built 4L60 and a Circle D 3200 stall combined with 4.10 gears. The dyno tuning was done with the converter unlocked with zero knock and air fuel at 12.9-13.0.
Does anyone have any ideas what's causing the dip?
Old Feb 20, 2011 | 10:28 AM
FirebirdSS's Avatar
Have a KB vette in the shop that has the same problem, haven't had a chance to take a look at it yet. Subscribed.
Old Feb 21, 2011 | 06:37 PM
Old Geezer's Avatar
Ne data logs for the pulls??
Old Feb 21, 2011 | 06:43 PM
JDMC5's Avatar
without any scan data, it's a guess.
Old Feb 21, 2011 | 10:35 PM
Gabbiani's Avatar
Knock retard (alot?) Or low timing there to keep it from koncking?
Need air/fuel data and some logs.
Old Feb 21, 2011 | 11:18 PM
STAR's Avatar
Don't have the logs, but I can tell you there was zero knock retard. The air fuel was 12.9-13.0 and the timing is 25*. We added up to 29* with no change in power and left at 25*.
Do you guys think it may be tire spin? If the dyno pull was started at 3800 rpms it pulls clean with no dip. Weird
Old Feb 22, 2011 | 11:09 AM
Sid447's Avatar
Possible valve-spring harmonic problem?
Old Feb 22, 2011 | 01:27 PM
James Linder's Avatar
One of these professional tuners on this forum should be able to tell you what this is in a heart beat. Oddest thing I've ever seen dipping and resuming back where you would expect. Makes you wonder if the measurement equipment is having an issue?
Old Feb 22, 2011 | 03:26 PM
ysb02's Avatar
Easiest thing to do is try another dyno / put some more weight in the back.
Old Feb 22, 2011 | 04:07 PM
STAR's Avatar
The funny thing is we locked the converter for one pull and the graph was smooth! I don't think its tire spin because when locked it made more power. Also, on some other pulls the dip occurs 1000 rpms sooner. It looks like I need to put it back on the dyno and make some logs.
