P0152 after dyno tune and rain
Old Feb 24, 2011 | 07:41 PM
candlelit's Avatar
Default P0152 after dyno tune and rain
500 mile engine (built 6.0)
This problem did not occur before the dyno-tune, and nothing was changed physically on the car.
Had it dyno-tuned by a reputable shop Wednesday. I picked the car up last night, everything seemed fine. Except the only issue I had then was the car died a couple of times when trying to shift gears from park to drive. Gave it some fuel when the rpms dropped and it was ok. Other than that, it ran pretty strong last night.
Today, I had to drive to work in the rain... 3 miles... (heavy rain), and the SES light came on and has been on ever since. It stopped raining this morning & the roads are dry. Also the car started running like crap, almost like it was running on 2 cylinders, ie "misfiring dog." The transmission seemed to shift funny, acceleration was really slow, and of course the car feels rough. However with the SES light on it would run strong when it wasn't in its "misfire" running mood.
Stopped in to Autozone, had it scanned, P0152 (bank 2 sensor 1).
Ideas?? If I decide to replace that o2 sensor should I get direct fit Bosch, Denso, or NGK?? Guy there also recommends replacing both front o2 sensors??
Old Feb 25, 2011 | 01:31 PM
candlelit's Avatar
dumdittydum...
Old Feb 25, 2011 | 03:10 PM
foff667's Avatar
LS1TECH Sponsor
Sounds like a front o2 sensor issue to me, might want to check the wiring, etc. High probability it has 0 to do with you getting dynotuned.
Old Feb 25, 2011 | 03:48 PM
bearcatt's Avatar
Originally Posted by candlelit
dumdittydum...
LOL, If I was going to replace the O2 sensors, I would probably put back in as close to the original AC Delcos, Densos or Delphi's... but that's just me.
Have you checked the O2 sensors under the car to see if the connections and wires are ok ?
Have you tried to disconnect the battery ground cable for 30 seconds to allow the adaptive memory in the PCM to reset ?
Do you still have Cats? If not you may need to install some O2 simulators.
Even with new O2 sensors, you can still throw codes without cats.
Old Feb 25, 2011 | 07:53 PM
candlelit's Avatar
yeah my tuner suggested Delco's too but they're more than I want to pay for. I think Advance Auto wanted like $130-$170 for them. So I'm looking at the Denso's and the Delphi's.
I got underneath there and checked out the wiring, it seems fine. I even cleaned out the connections, took a heat gun to my o2 sensor & burned off any containment on it, nothing helped. My car has aftermarket cats & I don't recall seeing any o2 simulators. I haven't reset the battery so I'll go try that real quick.
My tuner said to bring my car by in the morning & he'll look into it.
Old Feb 25, 2011 | 08:20 PM
bearcatt's Avatar
If you can wait for the parts to arrive via mail order, here are a couple of sponsors. If not at least you have the part numbers.
I think you can do better than what Advance is asking for those.
http://www.oehq.com/acdelco_20001887...ns-Sensors.htm
These O2 simulators will tell your PCM what it wants to know.
http://www.afterthoughtsauto.com/o2sim.html
