Worth it to tune a stock T/A?
Is there a point to tuning it? I know I am going to gain some hp/tq and can correct some things(check engine light etc)but is it worth the $$? Only plans are for LT's but then again I have had the car for almost 6 years and haven't done them yet ha. What is changed to help a stock engined car out besides shift points and shift firmness? Thanks in advance.
Thanks Frost, I had talked to you a year ago or so about my SS. I sold it thats why I never sent it to you.
Any typical gains I could see with the tune? LT's may not come for a while thats why I want to send it. I got other things to take care of and I want to buy some ARH's or SS Works so I gotta save up. 4 month old are expensive!
Smog pump/air tubes deleted, egr delete so throwing codes for secondary air etc, want the codes deleted for emission's purposes. So yup, gotta fix my stock car plus the slightly bigger injectors that are now on the car I'm sure are doing more damage than good even if they are only a couple of lbs bigger.
I didn't know you could do so many corrections on a basicly stock car. Crazy.
Does elevation have anything to do with the tune? El Paso is at 3500-5200ft above depending on day.
EDIT: oh yeah an air intake will almost always throw your fueling off. It's changing the way the air flows over the maf sensor. Remember airflow over a cross section is not necessarily completely linear, any kind of bends/ angles will cause the air to flow more toward one side, kinda like how water does.
I put a cold air intake, a no name catback and a half *** tune on my 03C5 and ran 12.98 @ 109.00. With a better tune it would have ran 12.7-12.8 @ 110-111, I'm sure of it. And that's with an auto and 2.73 gear.
) and a cutout that i usually leave open. my car is mostly a highway car that i use too and from school. i have always been wondering if getting a tune from frost would help the mileage at all. however i will say, that it is not my primary intention. i just want it to run optimally, or as close as it can come with the A4. any advice? sorry for the
My $ 0.02
Don't worry about the
, this is all here to help everyone out.
