Burned pin on PCM, fix?
Old Mar 3, 2011 | 03:10 PM
velox65's Avatar
Default Burned pin on PCM, fix?
I have a burned pin on my PCM, doesn't affect anything as it is unused at the time until I remove my manual valvebody. Question is, can this be repaired Or do I need a new PCM to tune for my head cam stall swap?
Old Mar 4, 2011 | 10:17 AM
velox65's Avatar
bump^^^ could use some info, Im going to be needing a tune shortly.
Old Mar 4, 2011 | 11:21 AM
bigboykilroy's Avatar
Can you post a pic of that is damaged so we can get a better idea how bad it is?
Old Mar 4, 2011 | 11:43 AM
velox65's Avatar
I should be able to, it's just one pin that seems to have shorted out and burned down to the plastic, the wire itself it intact just the pin is toast
Old Mar 4, 2011 | 12:01 PM
on the pcm itself?
Old Mar 4, 2011 | 04:47 PM
CalEditor's Avatar
I have a friend that can repair PCM's
PM me and I will forward your info
Old Mar 4, 2011 | 06:26 PM
velox65's Avatar
Yea the pin on the PCM itself, not the wiring harness. And I will pm you
Old Mar 5, 2011 | 04:39 PM
slowpoke96z28's Avatar
sounds interesting. i been wondering about that.
Old Mar 5, 2011 | 04:53 PM
CalEditor's Avatar
Details will be coming out soon
