E85 Support in Gen IV
With that being said, i believe that the E38 PCM can out of the box be capable of Flex-Fuel if the right calibration/tables were available to be changed. I have hp-tuners, but I don't believe all of the tables I need are available in it.
The flex-fuel Vortec 5.3L doesn’t even require a special fuel sensor. The first flex-fuel engines used a light-reactive sensor to measure fuel composition from 100 percent gasoline to 85 percent ethanol. The Gen IV has a virtual sensor—software programmed in the E38 ECM with no separate physical sensor. Based on readings from the oxygen (O2) sensors, fuel level sensor and vehicle speed sensors, the ECM adjusts the length of time the fuel injectors open for the type of fuel used. Within a fuel miles after filling up, the E38 controller determines what fuel is powering the Vortec 5.3L and manages the engine accordingly.
^The same is true of all other Gen IV v8's with the E38 PCM.
Running E85 is easy enough, change stoich, fill it up and be done, but it would be nice to not have to worry about a re-tune between fuels, or not being able to find 93/E85. There's also timing adders for alcohol, etc.., so you'd be able to have a E85 tune side-by-side a 93.
I was able to enable the flex-fuel field in hp-tuners, and fill up with e85, and the trims just go out of control and the command AFR doesn't change like it does in other Flex-Fuel vehicles. I assume this is because the necessary calibrations/tables aren't filled out in our PCM's. Does anyone have any insight or ideas on this? I'd really like to be able to jump between E85/93, since there's over a 70 cent difference a gallon here in st. louis. I think it would also be very nice for tuners to have the ability to throw 3-4 more degrees of timing at a motor when it's on alcohol and when not.
Anyway, discussion? Ideas?
Thanks,
Mike
Thanks,
Mike
I haven't looked into part numbers for them yet.
GM talks about it here, but there is little data aside from this:
http://www.gmpowertrain.com/Powertra...10_LZ4_LZE.doc
