Diablosport for egr and air
LS1Tech Sponsor
if it's a newer version 7198 on a 9rXX revision number, no... that functionality was removed a few years ago due to EPA regulations... you'll need to get a custom tune made for it in order to have that done... hit me up if interested...
if it's an older one, on a 2.xx revision number... then yes, you should be able to disable them yourself.. it should have them listed in the OBD section under Modify Tune...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
what revision is your predator on?? revision number is at the top of the screen when it's at the main menu...
It is brand new, so I assume the new version, and yes I am interested in getting the tune. I will pm you with the revision when I get home and I really appreciate the help!
I have a 2.14 revision number on mine. Just like 06MonteSS said, go to Modify Tune and it will list EGR and AIR under the list of things to modify. I had anoth Predator for my Camaro and it was a newer version that was made in AUG 2010 and that one did not have AIR/EGR options.
