Swapped Column. Now No Start.Help!!
94 Trans Am just replaced column. Finished up. Hooked up battery. Went to turn over and it wont crank. Security Light comes on and stays on for a while but nothing. Can I assume it is something with the chip in the key?? The column came with a key. I never noticed a security light before I did this job so I dont know whats up ewith that. Maybe somebody can explain me how to test the resistance of the key and make sure it matches the one on column.
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!
If so disconnect the column harness and measure the resistance across the two small wires(white) and make sure it is the same or within 10 ohms of the key pellet. If not you probably have a break in the wire or problem in the switch.
Thanks again
