MAF sensor w/ Carb Style intake??
Old Apr 4, 2011 | 09:43 PM
au1991rx's Avatar
Default MAF sensor w/ Carb Style intake??
Is there a way to put a MAF sensor on top of a carb style intake above a 4 barrel throttle body and be functional? I know it is not the perfect place and not necessary as I could run speed density but would like to know if anyone is doing this. I am getting closer to a PCM/harness/base tune purchase on my conversion and am trying to get together a game plan. If not or too expensive I will just run SD. Thanks for the info.
Old Apr 5, 2011 | 01:13 AM
minytrker's Avatar
You would have to run a carb hat or turbo elbow then go to the maf then to an air filter. I would just go SD and be done with it.
