can i pull codes with edit?
Old Feb 19, 2004 | 11:33 PM
02redSS's Avatar
Default can i pull codes with edit?
i know if i program it will clear the codes...but i want to be able to see what codes the light is giving me...can i do that with ls1edit? i have edit but no logger.
thanks
Old Feb 19, 2004 | 11:54 PM
SS SLP2's Avatar
no can do, must have a loger or go to auto zone who will normanly read them for you ,good luck Johnny
Old Feb 20, 2004 | 11:20 AM
Bill Bowling's Avatar
thanks
How do you use LS1Edit without a logger?
BowlingSS
Old Feb 20, 2004 | 06:40 PM
02redSS's Avatar
BowlingSS
well i set my part throttle shift points, my WOT shift points, my TC lockup points, set my TC to lock up at the top of 3rd at WOT, set my gear ratio, tire size, deleted torque management, deleted the rear o2 sensors, delete air pump codes, moved my rev limiter.
and wouldn't you know, none of that stuff required a logger to accomplish correctly
Old Feb 23, 2004 | 10:43 PM
RATICAL WS6's Avatar
May I ask how you set your TC to lock at the top of third and how well it works. I was thinking of doing this to improve mph in the 1/4 mile. I would like mine to lock up and stay that way at say 95mph and up under full throttle.
Thank you.
Old Feb 24, 2004 | 09:21 AM
JustAnotherSS's Avatar
A4 TCC Tab - TCC MPH Threshold:
These values are for WOT operation. They indicate at what MPH the TCC will lockup and release in each gear. Make sure your release values are smaller than your apply values.
Old Feb 24, 2004 | 06:43 PM
Thank you.
