Quick Question.
Second. It's all the time whether part or full throttle.
Here's the whole story. Years ago, I had ported stock heads and a comp216/220 cam and SLP headers. It was dyno tuned with LS1 edit. But my tuner couldn't seem to be able to get rid of the KR so he just pulled timing out at about 3500rpms. I always thought I could hear spark knock when I gave it throttle but would go away immediatly. Since then, I broke a valvespring and made a mess of things=rebuild.
Now. I have forged bottom end. TFS215 heads. FMS F11 cam. Kooks 13/4 to 17/8 headers. Naturally the car drove like **** and I've tried to modify the same tune with EFILive. My friend allowed me to use his cable and wideband. I still have the cable but not the WB. I really don't know much of what I'm doing. I've put some more fuel in with the Lambda and took some timing out of it. Due to unfortunate situations, I don't have a choice but to drive the car regularly. I need to get this at least drivable.
I know I'm running out of injector on the top end but it's not going lean. Just at 98% duty cycle so I put the limiter at 5500rpm. Should I reload a stock tune and start over or change something else.
All of my mods are as follows:
Lid
Ported stock maf
ported TB
LS6 intake
TFS 215 heads
FMS F11 cam 228/230 .576/.595 114
Kooks headers
hi flow cats
3in to 3.5in flowmaster merge
3.5in all the way to back with a dynomax bullet
Lid
Ported stock maf
ported TB
LS6 intake
TFS 215 heads
Kooks headers
hi flow cats
98% IDC means you probably need to get bigger injectors but it doesn't necessarily mean that you are getting ready to go lean. The number is just a calculation. I've tuned cars that were running stock injectors and sometimes push the IDC to 120%, but the fuel was always there. You should start looking for bigger once you get around 80%, but that doesn't mean that it's life or death.
Either way, to get you drivable you need to fix the airflow tables (VE and/or MAF).
