commanded afr at wot
Why are the values in your commanded AFR so rich? Who was the car tuned by beforehand? I am wondering if someone raped the command fuel table to avoid having to properly dial in the fueling.
Then most likely copy it over to stock and start over fresh.
Once its working the 02 should show up on the scanmaster display depending on what version you have.
Then follow the Calc.VET tutorial on the EFILive forum to dial in your MAF, and VE, PE (WOT) table, etc.
I made a conversion table you can use for your commanded AFR/EQ/Lambda whatever based on different types of gas.
