need help bad
Old May 7, 2011 | 08:39 PM
kosimoto's Avatar
Default need help bad
Just put tranny back in and had running just fine, all of a sudden it quit, no spitting or sputtering. any ideas
Old May 8, 2011 | 02:46 PM
kosimoto's Avatar
nobody ha an idea what it could be?
Old May 8, 2011 | 03:06 PM
MUSTANGBRKR02's Avatar
Check everything that you touched. If it ran fine before and all you did was the trans you may have something loose.
Old May 8, 2011 | 04:10 PM
kosimoto's Avatar
I had the car running for about 5 minutes trying to get up to temp, and then it just died like if someone turned the key off. I have gas in the tank.
Old May 8, 2011 | 04:27 PM
2xLS3's Avatar
Do you have fuel pressure?
Do you have spark?
Start with the basics
Old May 8, 2011 | 09:57 PM
kosimoto's Avatar
no spark
Old May 9, 2011 | 06:40 AM
Did you undo any grounds on the back of the heads?
Old May 9, 2011 | 06:58 AM
kosimoto's Avatar
no i didnt
Old May 9, 2011 | 10:01 PM
kosimoto's Avatar
I think my computer took a crap
Old May 10, 2011 | 05:12 AM
2xLS3's Avatar
Does it do the fuel pump prime when you first turn on the key?
Did you try a noid light and check for injector pulses?
If you have no spark, did you make sure there is 12 volts going to the coils?
If the PCM is truely dead, do a search on the 12200411 pcm upgrade
Old May 10, 2011 | 07:06 AM
kosimoto's Avatar
pump turns on when key is turned on
ok
Old May 10, 2011 | 11:11 AM
joecar's Avatar
Don't jump to conclusions, diagnose it (see link below) otherwise you'll waste time/money and still not know what the problem was.
http://www.gearchatter.com/viewtopic8646.php
Old May 12, 2011 | 07:19 PM
kosimoto's Avatar
Hey thanks joecar.
Old May 12, 2011 | 08:46 PM
kosimoto's Avatar
fuses are good, when i first crank it over, it act likes it wants to start but it doesnt and just keeps cranking over. oh yeah, the computer is good. thanks to mechanic
Old May 12, 2011 | 09:25 PM
CalEditor@PCMCalibrators's Avatar
Did you have the starter out? The Crank Sensor is located near the starter. The connector may have been knocked loose
Old May 12, 2011 | 09:43 PM
99_LS1_WS6's Avatar
Check the intake sensors, I had connector to break and it did the same thing. Turned over but wouldnt start.
Old May 15, 2011 | 04:42 PM
kosimoto's Avatar
99 ls1 are you talking about the IAT sensor.
Old May 17, 2011 | 08:29 PM
kosimoto's Avatar
ok, I put the tard in retard. Some how I pinch the camshaft sensor wires when put the tranny back in. Let this be a lesson for all you future tranny installer. thanks for all your input.
Old May 17, 2011 | 09:37 PM
2xLS3's Avatar
Glad to see you found the problem and posted the results
Old May 18, 2011 | 07:04 AM
kosimoto's Avatar
thanks, $567.00 later
