Mailorder tune , big problems after cam.
You had your hands on every single part that CAN cause a misfire during those mods. Which is why I suggested you DOUBLECHECK everything. It stands to reason the affected areas during the mods are the cause and source of the problem.
The misfire is something real and physical to find. Your timing isn't too advanced; it's lower than stock at no-load up to around 21-2300 RPMs except for deep decel.
The fact that it's ok during first startup (no correction from O2's; open loop) and then, once it goes into closed loop it runs poorly just re-enforces a plain old misfiring cylinder. The misfiring cylinder passes off it's unused oxygen content to the front O2 on the side with the issue. The PCM is a little dumb and mistakes this misfiring cylinder for a lean condition and begins adding away at the fuel to try to 'fix' what it thinks is a lean condition. It can't, and it over fuels that side of the engine as a result. As this adding goes on, the car will run worse and worse.
To figure out which side of the engine the misfire is occurring on (if you have a scanner), look for the side that has very high positive long and short term trims. That's the problem side.
Alternately, unhook the O2s and the car will run open loop. Unhook the battery and it will reset previous learning. You can then run the car in open loop to search for the problem more safely because the PCM won't drown the offending side with closed loop operation.
There is a real physical problem here. We can certainly get it fixed for you if you'd like, and I'd be happy to answer any questions.
Things happen and can happen at any time. Sometimes it is related to what has just been done, and it probably is, but do not focus off of any one thing until you verify that it is correct. Sometimes things happen and it is just a coincidence.
Point I am making is take a logical approach to diagnosing the problem starting with the basics first.
Do the simple things first...they are usually the culprit. Did you try unhooking the MAF yet? If you over think this, you could end up with a bunch of little problems that take forever to get right. You paid Frost for his expertise. Use it. I've been around this a long time and everything he said is dead on the money.
Whomever he had working on his car "installed the coil bracket backwards", and one side had total misfires. Since the implication is that the poor performance was somehow my fault (this IS posted in the tuning section), I thought I would let anyone reading know what happened.
Why would he take the packs off the brackets anyway?
