looking for a e85 tuner in nw indiana, mich, ill
We have a facility in Rockford. The tuner has done many E85 tunes and he has hundreds of hours of data-logs.
Contact programmer@pcmcalibrators.com for information
Be VERY careful running E85 on stock injectors, it WILL run lean, last thing you want is holes in the pistons. The timing curve on E85 is very different than gas. It will run fair on E85 with a gas timing map, but not run as good as it will on a true E85 timing map.
