two different map readings same car
Old May 14, 2011 | 08:48 PM
500@10psi's Avatar
Default two different map readings same car
is there a different sensor for the pid map and the sens map it seems that i might have a two bar map as it reads 50 kpa at with engine off from the sens but with the pid map (not custom) it will read atmospheric >98 wtf??
Old May 15, 2011 | 11:03 AM
jimmyblue's Avatar
Moderator
In HPTuners the 2-bar (and higher) OSes add a PID for the MAP.
The OE / stock one is a dumb voltage translation with the stock
scale factor. If you read 50kPa KOEO then you have a 2-bar MAP
sensor installed and are looking at the wrong PID.
Old May 15, 2011 | 01:17 PM
500@10psi's Avatar
thanks, still a little confused. i bought the car with it installed i have the stock 2000 os i guess i will try a wot run and see what it logs. How does hpt derive the PID table map reading?
