EFI Live questions
Old Jun 5, 2011 | 12:03 AM
SSpdDmon's Avatar
Ok - here's some stuff to try. There were some things I changed/left alone based on some assumptions:
1) Stock injectors (28.8 lb)
2) No EGR
3) No AIR pump
4) EVAP still hooked up
5) No cats
6) Front O2 sensors still good
7) Stock 3.42 gear ratio still
8) No significant change in compression ratio
9) Stock displacement
You can do a compare to the stock file you provided by opening this tune file first, then hitting Ctrl+F11. Once it's loaded, hit the red left/right arrows at the top to display the list of all differences. The fueling should be close for the Torquer cam. Keep an eye on the scanner for knock retard and crazy fuel trims. A WBO2 is a very wise investment and I wouldn't advise rompin' on the car too much until you're able to get one hooked up.
File Type: tun
Old Jun 5, 2011 | 10:45 AM
kevindglenn's Avatar
I believe that even if his tuning came from someone else's, he should still be able to use the tuning on his own.
Old Jun 5, 2011 | 09:30 PM
hixwv's Avatar
not 100% sure about 1 3 or 5. cant wait to take a look at this and start playing around with it tomorrow. ill let you know how things go. looking up WBO2 now..
Old Jun 5, 2011 | 09:34 PM
SSpdDmon's Avatar
It's not his software, it's his friend's....and the dude is used to tuning other platforms. They can spend half the summer trying to figure it out or I can get 'em going in the right direction with a strong base file for them to dial in the rest. I'm just trying to be a nice guy...
I won't stand in their way if they want to read and learn more about how to tune. But, if I have a little info that can help them out and feel like sharing it - it's well within my right to do so...thanks!
Well - #1 is super important. Find out what injectors you have before you flash the car. WBO2 = wide band oxygen sensor. Check out Innovate's website. I run an LM1, which may have been replaced by an LM2 now.
Old Jun 6, 2011 | 09:37 AM
hixwv's Avatar
it was late last night when i posted that haha. It has the stock injectors and the cats are there but may be gutted. the SES light is not on so im guess most of the emmissions system is up and running? i think the EGR may have been bypassed. laptop will be here in a few hours, cant wait
Old Jul 5, 2011 | 09:51 PM
hixwv's Avatar
I think I may have gotten some bad gas. Everything was fine, I filled up and drove 5 miles to my house. Later when I left somebody said they could smell gas as I left. And the last few nights its been cranking more and more before it starts. turning over three or four times. But only after it cools off. It always hit and started on the first crank before that fill up.
any ideas?
Old Jul 6, 2011 | 08:56 AM
SSpdDmon's Avatar
any ideas?
EVAP system? What tune did you end up flashing in the car?
