EFI Live questions
Old May 23, 2011 | 11:05 AM
hixwv's Avatar
Default EFI Live questions
I have a 98 SS and just put a cammed ls6 block in it with stock intake, heads, and flowmasters. It needs programmed/tuned. Doesnt like to idle. My buddy has a EFI live programmer he's used to put tunes in his duramax trucks. My question is can we use it to do my car? where can I get a tune? what do i need to buy/get?
Old May 23, 2011 | 11:11 AM
SSpdDmon's Avatar
Assuming he's running the current version, yes he can use it to tune your car. You will likely need a WBO2 sensor to do a half way decent job of it. If y'all are unfamiliar with what you need to change to have a well running vehicle, there's a LOT of reading that you need to do. It's not just flipping a few switches and tah-daahh, it's perfect.
Where are you located? What kind of cam did you put in?? What are the supporting mods (lid, headers, injectors, etc)???
PS - I highly advise you don't drive with anywhere with more than 30% throttle until you get it tuned. Even as it sits, there's likely too much timing down low and not nearly enough fuel up top.
Old May 23, 2011 | 03:12 PM
hixwv's Avatar
it is the current version, and we are not very firmiliar with it. his tunes came from somebody else.
my specs: 6 speed, ls6 block, arp head studs, texas speed torquor v2 cam 232/234 595 598 112+2, thunder racing dual 650 lift valve springs titanium retainers, 7.4 hardened push rods, stock 241 heads, ls6 valley cover, flowmasters, everything else bone stock.
Old May 23, 2011 | 03:13 PM
hixwv's Avatar
oh and im in southern west virginia. between lewisburg and beckley.
Old May 23, 2011 | 04:16 PM
SSpdDmon's Avatar
Shoot - wish u were closer. Hell of a lot easier to show things in person. Well, I can tell you where certain things need to be as a base. The hardest part will be to get the AFR dialed in. For that, a WBO2 will come in handy as I mentioned. Shoot me a PM when you're ready to start messin' with it.
Advice is free. Paypal donations for a satisfied result will not be refused.
Old May 23, 2011 | 06:14 PM
hixwv's Avatar
haha good deal. just a warning i know NOTHING about this
Old May 23, 2011 | 06:33 PM
SSpdDmon's Avatar
http://www.efilive.com/index.php?opt...130&Itemid=134
Old May 24, 2011 | 09:14 AM
hixwv's Avatar
my buddy wants to know if i have to buy a vin license or something? and he said he could download the stock tune to his laptop?
Old May 24, 2011 | 09:51 AM
SSpdDmon's Avatar
98's are unlimited with EFI Live - so no he doesn't need one. As for the stock tune, I would read what's in the car and use the compare feature to one of the stock 98 files posted up over at http://www.tunefiledepot.com/.
Old May 24, 2011 | 11:08 AM
hixwv's Avatar
whats in the car is stock. never been tuned. so if i compared it to another stock 98 tune wouldnt it be the same?
Old May 24, 2011 | 11:40 AM
SSpdDmon's Avatar
Like a fabricator says, "measure twice & cut once." Unless you're the original owner of the car and be 100% certain nobody has touched it, I'd double check. That way you know you're starting from a clean base...
Old May 24, 2011 | 01:06 PM
foff667's Avatar
LS1TECH Sponsor
The problem with 98's is that they are a single segment file so there could, technically be a dozen or more operating systems for a single vin...trying to find the same operating system may prove difficult to compare against.
Old May 24, 2011 | 02:19 PM
SSpdDmon's Avatar
Yeah...doesn't hurt to try though.
Old May 26, 2011 | 02:22 PM
SSpdDmon's Avatar
Hix - when you get a chance, try to read the stock file out of the PCM and post it up. If you can't attach it here, you can do it over on the EFI Live forums and we can continue our discussion there.
Old Jun 2, 2011 | 03:35 PM
hixwv's Avatar
heres the stock tune, took a few days lol
File Type: tun
Old Jun 2, 2011 | 04:02 PM
SSpdDmon's Avatar
I'll get you a base to test for the weekend.
Old Jun 3, 2011 | 09:23 AM
hixwv's Avatar
ive been reading up on this stuff all morning, and I have the laptop next to me with my stock tune and the tune off that 99 that didnt work to just compare the too. there is A LOT to take in.
Old Jun 3, 2011 | 10:35 AM
SSpdDmon's Avatar
99? You have the factory '98 PCM in there, right??
Old Jun 3, 2011 | 11:39 AM
hixwv's Avatar
yeah the tune i found on here was for a 99 but it said 98, it wont even go in the car. i sent you the stock 98 tune that we pulled from her. i was just comparing the two on the laptop
Old Jun 3, 2011 | 12:29 PM
SSpdDmon's Avatar
Oh - I was going to say... Yeah, you can't throw the '99 tune in the car. Different OS, different PCM pinouts for some wires, etc.
