Idle issue
When you are cruising along and come to a stop the car acts like it wants to die..it low idles for a few seconds, then pops back up to the commanded idle. Then it's fine. I was thinking it's in the Throttle Follower Tables..any ideas?
I've had this issue with several cars and the VE tables and resulting fuel trims need to be correct for that part of the map, then a few of the things that can be used to correct it are the throttle follower, throttle cracker, IAC and stall saver.
Getting the airflow dialed in for that part of the map, setting the IAC correctly, and having a properly sized bleed hole in the TB will make a huge difference in correcting the hanging idle. Putting some additional timing in that area can helpen soften the effects of the big cam and help it too.
Now I'm tryin to tune the AC portion when you turn it on, it bumps up to 2500 for a couple sec..then comes down to normal.
Air/Fuel ratio has a big effect on the surge in my experience.
Brad
Are you running open loop idle, or closed loop?
I drilled out the hole to a 1/4", went into the VE Table and leaned it out by what I think would be close..and it's on point now. Idle is 14.5-14.7, depending on engine temp.
MAF is disabled, STFT's are disabled, aswell as Closed Loop. Just setting it up with a decent VE Table before turning on all the other stuff..
The only thing holding me up now is when I turn on the AC it goes to 2k for a few sec..then comes back down.
