Getting weird knock
Im almost 90 % sure its false knock, Ive checked and ran just c16 and it still 'knocks'. Also note, i re-used my old knock sensors from my old motor, they didnt have many miles on them. Could it be the the wiring harness going to the sensors?? Any help. I know the wires of these may be jacked up because I have had fifty million different intakes on my setup. Thanks guys
Should i turn down the sensitivty of the sensors as well or is that just wasting time?
i had a bad harness so i replaced it and took it back to the dyno and it was the same story. however it wasnt all the time it would pick up knock worse on some passes then others. then it hit me. its hot as ****. the dyno room conditions were 109 and the air was thin as ***** and hot as hell. we let it cool off for the final couple passes and the final pass was even a spray pass and zero knock. if you have full faith in your tuner like i did because my tuner is a complete badass id chalk it up to being this wicked southern heat, higher than normal water temps, and false knock.
High temp air does cause real knock, thats why FI people use intercoolers, CO2 sprayers and water/meth injection, just to lower intake air temperatures.
Be very careful with knock, don't just desensitize your knock sensors because you may damage the engine.
If it goes away with cooler temperatures, beware. It is real knock and should be dealt with first.
If knock doesn't go away with this, then it is false knock for sure
