where do you get the PCM pins for cheaper
Old Aug 14, 2011 | 01:07 PM
FakeSnake's Avatar
Default where do you get the PCM pins for cheaper
Like the title says where can you get the pins for cheaper then the dealer sells them for?
Old Aug 14, 2011 | 01:35 PM
Old Geezer's Avatar
Mouser is where I got mine...Not expensive.
Old Aug 14, 2011 | 02:25 PM
minytrker's Avatar
How much are they from the dealer?
Old Aug 14, 2011 | 03:28 PM
FakeSnake's Avatar
2.00 a piece and i need close to 50 of them...
Old Aug 14, 2011 | 04:03 PM
2xLS1's Avatar
eficonnection
Old Aug 14, 2011 | 04:57 PM
shoemike's Avatar
Ballenger Motorsports
Old Aug 14, 2011 | 06:17 PM
popethe5th's Avatar
why do you need 50? its gettoh but the junkyard has plenty of them. if your re-pinning for the EFI 24x then stock pins are the same as LS pins
Old Aug 14, 2011 | 06:20 PM
TransWS6Am's Avatar
Seriously? nice first post! Mouser has them cheap
Old Aug 14, 2011 | 06:37 PM
minytrker's Avatar
50, wow what are you doing? I got all mine from a few cut up harness's. If you need that many and they dont need to be new I would get them from junk yard.
Old Aug 14, 2011 | 06:43 PM
TransWS6Am's Avatar
just get um from moser for $0.30 a peice and save your self the hassle of trying to use old pins.
Old Aug 14, 2011 | 09:22 PM
minytrker's Avatar
just went to there site....holy **** they have a lot of stuff...I never used them before thanks for posting about them
Old Aug 14, 2011 | 09:54 PM
FakeSnake's Avatar
can someone link to whatever site your talking about please
Old Aug 15, 2011 | 07:00 AM
Old Geezer's Avatar
Google is your "bestest friend"...
http://www.mouser.com/
Old Aug 15, 2011 | 08:21 AM
edcmat-l1's Avatar
Originally Posted by old geezer
google is your "bestest friend"...
bff? Lol :d
Old Aug 15, 2011 | 10:49 AM
Mike454SS's Avatar
I buy all my pins and connector housins/seals for EVERYTHING I wire on my cars from Mouser...when it's a show car, I don't re-use anything from a junkyard harness...I also hate buying pigtails from GM because they come with all white wires on them usually (or maybe all grey, I forget) rather than proper color coding...plus when you are connecting a lot of wires (say on a new harness you're building for an engine swap)...you want to run the correct length wire and crimp both ends to the pins rather than solder...soldering makes the harness bulky, gives it a place where you can't let it bend, and is very time consuming in comparison to crimping pins on.
Also...I need to update my old thread (if I can find it)...I have a thread where I've put connector and pin PN's for some of the more common stuff I've wired into these cars...if I can find it I have some stuff to add for coil packs.
The best part is the prices.
