Cluster swap
Old Aug 29, 2011 | 08:50 AM
dphc18's Avatar
Default Cluster swap
My tach is not working in a 99 T/A so I took a cluster out of my friends 2000 T/A to test if cluster i s the problem and the car only cranks and won't start with loaner cluster but it still starts with the broken one. What do I have to do to let it work with loaner cluster.
Old Aug 29, 2011 | 07:17 PM
dphc18's Avatar
So nobody knows if your are supposed to be able to swap clusters with out flashing anything or something b/c its not working for me
Old Aug 30, 2011 | 12:15 AM
Dirty Vegas's Avatar
The tach doesn't die for no reason. Is there an SES light? Do you know what code has been set?
Old Aug 30, 2011 | 12:29 AM
itsslow98's Avatar
Sounds like a wiring issue or a computer problem not a cluster problem. Clusters are interchangeable 99-02 and have no effect on the motor running or not.
Old Aug 30, 2011 | 01:07 AM
Cluster has a direct effect on the motor running or not. Try to start your car with the gages fuse pulled. Won't happen.
Old Aug 30, 2011 | 01:32 AM
itsslow98's Avatar
Didnt know that, guess its not the same in my mustang. I ran it without any cluster wired at all. I then wired up the cluster and nothing changed.
How does the cluster affect the car running though?
Old Aug 30, 2011 | 09:37 AM
Were you running a stock harness? I'm pretty sure if the PCM doesn't get the right signal from the BCM, it will cause a no start condition.
Old Aug 30, 2011 | 10:28 AM
dphc18's Avatar
I took the complete harness out of a 99 and did an LS swap on 95, the engine, interior harness and the bcm and cluster are all original to them selves, I have no Idea if the tach was broken I just finished this swap and started car runs fine except for tach so I was swapping cluster to see if that was the problem but then I ran into the no start with the other cluster,
Also I went to an exhaust shop to get some work done on it yesterday and the car would not start when I went to pull in so I opened the hood and shook wires back by cam sensor and then it started the scanner showed a cam sensor code so maybe I do have a problem in the harness by cam sensor, the sensor is brand new from GM so 'm hoping its fine.
Old Aug 30, 2011 | 10:42 AM
Yeah buddy, that's what I was thinking. Without the proper signal from the cam/crank the PCM will guess and either be right or 180 out. So it will start sometimes, and backfire other times. You have a break in the harness somewhere, or a bad cam position sensor, or a worn out magnet on the cam, or the cam bolts came loose from the sprocket and the cam is walking.
Old Aug 31, 2011 | 09:48 AM
dphc18's Avatar
Do you have any wiring schematics for harness going to sensor?
Old Aug 31, 2011 | 11:26 AM
http://www.ls2.com/boggs/dtcs/DTC%20P0343.htm
Complete GM guide on how to diagnose/repair.
Old Aug 31, 2011 | 12:26 PM
dphc18's Avatar
I'm getting PO342 low voltage, does it matter if I use the high voltage code info you gave me?
Thanks
Old Aug 31, 2011 | 02:26 PM
I recall it being the same steps. Search that site.
Old Sep 1, 2011 | 08:05 AM
dphc18's Avatar
It was a bad cam sensor connector, code is gone and tach works now thanks for the help!
Old Sep 4, 2011 | 07:42 PM
jmoss209's Avatar
Im trying to get my cluster to work....i put everything from a 98z28 under hood into a 00z28 i didnt change wiring under dash tho and i left the traction control abs module in the 00 as well....my gauges r not working in the 00 with the 98 motor tranny n ecu how can i fix this problem someone plz help me i need gauges theyre important when smashin on mustangs lol!!
