P1637 CAN Link ECM/ABS Control Module Circuit/Network
Old Sep 17, 2011 | 10:57 AM
SmokeU's Avatar
Default P1637 CAN Link ECM/ABS Control Module Circuit/Network
I used my multimeter and checked the voltage on the speed sensor and they checked out . No ABS light or check engine light, I have been chasing this for a while. The only info I find is for Jaguars, not much other than my posts online.
Any help would be appreciated.
Old Sep 17, 2011 | 03:25 PM
SmokeU's Avatar
bump ......
Old Sep 17, 2011 | 10:30 PM
smooth01's Avatar
Is that code describing a serial data connection problem between the abs module and pcm, and not an error in the abs module itself
Old Sep 18, 2011 | 08:14 PM
SmokeU's Avatar
commonsense would think so, I checked the lines and its a good conection.could it be the module itsself that is the problem?Thanks for the response.
Old Sep 22, 2011 | 04:17 PM
SmokeU's Avatar
anymore help!!!
Old Sep 22, 2011 | 04:18 PM
SmokeU's Avatar
ttttttttt
Old Sep 23, 2011 | 06:17 PM
smooth01's Avatar
Did you check the power supply and grounds for the abs module to make sure its not intermittent,( no power, no communication) wiggle the connections, check for corroded terminals
Old Sep 26, 2011 | 04:33 PM
SmokeU's Avatar
Yes, but nothing changed, i am having a really hard time with this.any advice is appreciated.
