tps
Old Sep 26, 2011 | 02:53 PM
lawless_stunna's Avatar
Default tps
I went to have my car tuned and put on dyno but my tuner said that my tps will not go full throttel or was messing up because of my aftermarket throttelbody.Have anybody had this problem.
Old Oct 2, 2011 | 12:22 PM
SUPERMAN_00TA's Avatar
YES! I bought a knockoff TB and it had my TPS way off... it read at 10% throttle when at idle. I just got a new Fast TB.
Old Oct 2, 2011 | 01:21 PM
jimmyblue's Avatar
Moderator
Could be that you need to bend your gas pedal arm to take out some
slack. Look at your idle and your WOT TPS voltages, both working the
blade by hand and by pedal. And measure the blade open position
when it's against the stop. The TPS voltage is likely a symptom of
something mechanical, it's not the end in itself, just an indicator.
Old Oct 6, 2011 | 11:32 PM
kblehm's Avatar
I bought a cheep 92mm TB and my sensor wouldnt register WOT either so we adjusted the sensor and redrilled it to read WOT and 0 when closed.
