Is this normal anyone help
Old Sep 27, 2011 | 07:12 AM
rob00ss's Avatar
Default Is this normal anyone help
Since ive intstalled all motor mods in my signature and got car tuned. If u start it in the garage and let it run it smells like raw fuel and just stinks. Is this normal or does anyone have any ideas
Old Sep 27, 2011 | 07:26 AM
AutomagicLS1's Avatar
Do you have a wideband? That would tell you how rich it is. Might want to take it back to your tuner and get that ironed out.
Old Sep 27, 2011 | 07:30 AM
runtwrestlin's Avatar
I love that smell. It's almost as good in the morning as coffee
Did you remove the cats when doing said motor mods? (for some reason I can't see your sig)
Old Sep 27, 2011 | 08:07 AM
rob00ss's Avatar
Yes I do have a wide band and it goes all over the place at idle sometimes won't even register it goes so air fuel goes so high at idle and yes no cats long tubes and tsp true duels motor has heads cam intake 37lb injectors throtle body and running a 50 shot of nitrious
Old Sep 27, 2011 | 08:22 AM
Estes's Avatar
Were is your wideband mounted? I had a problem with it getting too hot and causing boggus readings. Other than that, no cats will do that. I have a 2010 Camaro with no cats and it smells just like that... wonderful.
Old Sep 27, 2011 | 09:01 AM
rob00ss's Avatar
I mounted it in the y pipe about ten inches from the header on the passenger side and it goes up to around 16 sometimes at idle. I don't
mind the smell just wanna
Ake sure it's not hurting
anything. It's good at full throttle in the high 12's
Old Sep 28, 2011 | 07:27 PM
Estes's Avatar
At idle the magic number is 14.7 You will have a variation where it will read 14.7 or around, very steady, then jump to 15-ish and drop to 13-ish, and then level back out. High 12 seems a little lean to me. I'm running 11.3 WOT.
