5.3 base tune w/ cam etc... Questions
Old 10-05-2011, 12:59 PM
BBC632Camaro's Avatar
Default 5.3 base tune w/ cam etc... Questions
I have a 2004 5.3 pickup motor that I put a professional products ls6 intake and a gm performance asa cam w/springs in it. Everything else is stock(heads etc). I have a pcm with a base tune on it from an 01 tahoe 5.3 with vats and all that deleted. I know I need to get this tuned but been debating about putting heads on it as well and thought I'd wait on the tune till then when I can afford the heads. So my question is... Can I safely run it as is with the cam and intake on it or will I have some major problems?
Old 10-05-2011, 04:28 PM
chrisfrost's Avatar
Is that a "hot" cam ? or similar in dur and lift ? Ultimately if it's running pretty good at this point , then most likely You can hold off on the tune .
Old 10-05-2011, 04:39 PM
This is the ASA Cam(12480110) with 226/236 @50 .525 lift 110LSA is what I'm using. Yes it is similar to the Hot Cam(88958733) which is 219/228 @50 .525 lift 112LSA.
I never did try to fire it yet as I have a few things to finish up on it yet and I didn't know if I should try to fire it or if I need it tuned first.
Quick Reply: 5.3 base tune w/ cam etc... Questions
