Going nuts.....another in-depth tuner question..$50 Paypal whoever figures it out.
#45
Hey, just thinking......can one bad 02 sensor make the other sensor throw codes?
Like if the Bank 2 sensor is wacked for sure......can it cause the other one to throw "slow response" and "low voltage" codes?
Or will the Bank 1 side run great no matter how bad the Bank 2 sensor makes thing run for that side?
#47
I was just gonna change out both of my 2 month old 02 sensors and see what happens.....before tearing into electrical things or trying a new PCM.
Just a thought....I'm still gonna get a full HP tuners log while its breaking up....hopefully someone here can make sense of it....before I do anything.
#48
#49
FWIW I have experienced this before and it turned out to be a bad O2. When the car was started cold the o2 voltage would not come down fast enough, taking too long to heat up and start reading properly. This high voltage would make it think it was too rich when it would switch to closed loop and pull all kinds of fuel temporarily- buck, hesitate, stumble, then come out and run fine. Took me a while to catch it just right on the scan tool to see what was going on.
