MAF problems..NEED HELP
Old Oct 26, 2011 | 08:15 AM
1998MysticZ28's Avatar
Default MAF problems..NEED HELP
Hey guys, the other day I started my car and it was running really bad. Idling high then dying on its one shifting weird, just drove like a real pos. So found out it was a code for a MAF sensor. Ok no big deal the car has 196k miles so it may of went bad. So I order a AC-Delco one and when I get it, it looks noting like the old one in the car. Is this correct?
Then instead of putting that one in I put a friends stock one which I know works and it runs a tad better but we are still seeing 0 input from the MAF in hptuners. Also the short and long term fuel trims are all out of wack.
Can anyone help me?
Chris
Old Oct 26, 2011 | 01:45 PM
anyone? we checked all the fuses and they were good
Old Oct 26, 2011 | 02:21 PM
2xLS1's Avatar
Measure the key on voltage between the pink and black wires the MAF connector with a volt meter.
Old Oct 26, 2011 | 02:45 PM
okay will do tonight. anything else I can try if that checks out
