LS1 stops while driving along
Old Mar 10, 2004 | 05:05 PM
c5bubba's Avatar
Default LS1 stops while driving along
Engine dies while driving along, after a couple of times the following codes
P0134,P0135,P0154,P0155,P0410,P1153. Headers with no cats and simulators in, but had the PCM programmed and back sensors turned off. Dealer says the O2 coes are what is causing the engine to quit but allow me to restart while rolling along
Any thoughts or ideas would be welcomed
Old Mar 10, 2004 | 07:52 PM
newbie_tace02's Avatar
car info?
Old Mar 10, 2004 | 08:36 PM
c5bubba's Avatar
99 C5
Old Mar 10, 2004 | 08:46 PM
99 C5
P0134,P0135, P0154, P0155 are from lack of O2 activity.
P0410 is Secondary Air Injection System
P1153 is HO2S Insufficient Switching Bank 2 Sensor 1.
What modifications have you made to the car? What was tuned in the PCM...There's really a wealth of knowledge in this forum, but more data is needed to help diagnose.
I'm no expert, just trying to help...
Old Mar 11, 2004 | 12:29 PM
c5bubba's Avatar
LG Headers with no cats, rear sensors turned off(but simulators there)
Old Mar 12, 2004 | 03:03 AM
blk~2000~Z28's Avatar
The 134, 135, 154, 155 are the ones I would be concerned about. It seems odd that your front O2 sensors are not working. Did you plug them back in? Try switching the back O2's (if you still have them) to the front, or buy some new O2 sensors and go from there. Your dealer is right though, whatever is causing those codes is causing your engine to die, but I doubt it is the codes that is causing your car to die (as worded above). If switching and or buying new sensors does not work then I would look elsewhere for the problem. Maybe to much oil getting to the sensors and messing the up. Maybe an exhaust leak that is causing the bad readings.
p1153 is from the O2 simm most likely, with O2 simms you should not see this code but unfortunately some people still receive them.
