lean condition @ wot
Old Nov 14, 2011 | 06:20 AM
Envied Z's Avatar
Default lean condition @ wot
Have a auto meter wideband on a 2004 Zo6. Recently put a can in and ever since my air fuel ratio shows 16.7 @ wot. The car doesn't seem to be running that lean so I
Thinking its a false reading. What could cause this? Bad o2 sensor?
Old Nov 14, 2011 | 06:52 AM
bene's Avatar
Trunion King
A cam in and not tuned?
Old Nov 14, 2011 | 07:11 AM
Old Geezer's Avatar
Scan/data log it, and see what's going on...
Old Nov 14, 2011 | 07:41 AM
Envied Z's Avatar
It is tuned and I scanned it everything seems fine nothing out of the ordinary.
Old Nov 14, 2011 | 08:42 AM
thunderstruck507's Avatar
Is the sensor installed close to the headers? Was it free air calibrated?
Old Nov 14, 2011 | 10:38 AM
Envied Z's Avatar
Installed right at the x-pipe...the problem is that I never had a problem before the cam. Speed Inc. Installed and tuned it. Should I go through the wiring with a fine tooth comb just to make sure they didn't **** with anything?
Old Nov 14, 2011 | 05:46 PM
bayer-z28's Avatar
Get a manual fuel pressure gauge and see what you are running at idle. Unless you want to wire one in, just make sure the idle readings are the same when comparing the manual to the electric. If your fuel pressure is below ~58psi at idle, you may either need a bigger pump or bigger injectors, or you've got a wiring/FPR issue.
If the Fuel pressure is within 58-60psi, you may need to have the tuner re-work it. A number of parameters can effect this.
Old Nov 14, 2011 | 06:09 PM
BLK02WS6's Avatar
Sounds like a false reading... I would check it over and if nothing glaring shows up, replace the sensor... or, better yet, can you get your hands on another wideband to verify with.
Old Nov 14, 2011 | 07:08 PM
YellowToy/A's Avatar
what does the signal of the wideband look like in closed loop going down the road? It should be a sign wave around 14.7. Use the narrow bands to check the wide band.
